I am owning a Little Phatty Stage Edition I and would like to know if anybody can tell me how to sync the LFO to the tempo of the song i am working on. So far i did this with just using my ears (which was around 98% accurate most times ) but the stuff i am working on now requires very precise timing of the synths. Thank you all for your input!! Until soon.
I have been talking alot with Roger OāDonnell. He had some design input with the little phatty and he also told me that he stopped using his little phatty as a sound processor with other sounds due to the inability to control the LFO via midi. I have little phatty tribute edition and am about to send it off for the upgrade. But even after the upgrade im pretty sure I wont be able to control the lfo via midi. If anyone knows something I donāt, please tell me!
(I start every response to emails like this with āIām not expert, butā¦ā)
You canāt unless you use Midi in which case you simply send clock from your PC or from the Drum machine then change the āLFO SYNCā Mode to Midi Clock instead of Internal.
Other Moog products like Voyagerās and Old School have ways to do this via the dozen or more input on the back panel. I have CV out on my LP and can use it to drive something else via CV but unfortunately even with the CV mod, itās got about 1/4 of the control and ābe-controledā capabilities of the bigger brothers.
But Midi can be your friend and if you have the code upgrade to support the ARP, you can use Midi for that alsoā¦
It works for me, I too have a tribute with CV out mod but that has nothing to do with it. I have 2.2 code and Midi works for both the LFO sync and the ARP sync.
Granted, they are doing [imho] far too much within CPU these days; yes, the LP is a rocketship packed with features but from a code perspective things can get out of hand so Iām sure thereās a scenario you can throw at it via Midi that will not work so well.
Midi clock is not the most efficient protocol and Iām using standard baud Midi since my LP doesnāt support USB. Likely it will be better with a USB based interface.
Just my 2 cents.
If you need more info, I can produce a short YouTube clip demonstrating this. btw: Iām using Logic 8 Express with a M-Audio MidiSport 2x2.
So this means i will have to upgrade my Phatty with the 2.2 code and then i will be able to sync the LFO with Midi?! What update is this exactly? Please let me know. Thank you very much.
So this means i will have to upgrade my Phatty with the 2.2 code and then i will be able to sync the LFO with Midi?! What update is this exactly? Please let me know. Thank you very much.[/quote]
There is a operating system upgrade availible for little phatty tribute owners. Makes it equivilent to a stage two except for the EGR auto function. I believe that function is for tribute models alone.
I think (i“m sure in fact) that Phatty OS 2.0 and above can sync LFO very well with midi. It is (it was, really) a very cool (and free) upgrade for the phatty.
You must send midi from your DAW or your beatbox to the phatty and that is. Your lfo are sync with the midi tempo. Before using it you must configure 2 steps in your Phatty but its very clear in the manual update that cames with the OS upgrade.
Of course the OS upgrade is free and you can download from the moog site.
I just did the Update and have been playing around with the Arp for a looong time. This is fun!! Haha. But: After connecting the LP to my MBOX, loading Pro Tools with a 120 BPM Session and setting the LP so that it takes the external MIDI as his clock nothing happens. Ccan someone help me out on this one? Thank you.
