sync to daw
having problems syncing the sub to cubase the arps and seq dont keep time with thw daw
how do i sync
thanks in advance
soundremo
https://soundcloud.com/soundremo
https://soundcloud.com/psycoholics2
You MUST disable MTC. Only midi clock must be sent to Synth
Which DAW are you using?
i am using cubase 6.5
how do i disable MTC
thank you in advance
soundremo
I do it like this in Cubase:
Press ctrl + mouse-click on SYNC in transport panel (F2). This opens “Project Synchronization Setup”.
Timecode source: Internal Timecode
Midi clock destinations/Midi clock out: Moog Sub 37
Midi clock follows project position: Yes/check
Always send strat message: Yes/check
Send midi clock in stop mode: Yes/check
Press SYNC on Sub 37’s arp, and press play in Cubase. You should hear that the arp-rate is synced to whatever BPM is set to in Cubase.
thank you i will give this a try
can´t fix strange behavior to record the pattern right in time inside DAW from own recorded pattern in Sub 37 (also preset pattern)!
Every Midi note is out of time, a little bit in front of quantisation. Try everything inside the DAW (ASIO, MTC, etc.) also in the main menue of Sub 37.
Do you try to record the Arp pattern inside Cubase? I use version 7.5.
