Sync MF-105M and MF-108M ?
Hi there Moog experts
I want to sync the LFO of the 108M with the rate of the pattern of the 105M, how do I do this? Can I choose how many steps in the pattern of the 105M are contained within one cycle of the 108M’s LFO? For example I have looked at using an external midi clock, but when 1 step = 1 cycle, the cycle becomes far too fast and messy.
Many thanks
PS I also have an LP with CV out, does this help? (noob)
x
Use a MIDI splitter to send the same clock to both, the rate knob then acts as a clock divider control.
http://www.midisolutions.com/prodqth.htm
like one of these?
Yes, that should work, send the MIDI out from the LP to the splitter then two MIDI thrus to your Foogers. Make sure the synth is actually sending the clock to its output!
This one is a standalone clock generator, and has two outs so you don’t need a thru box!
http://www.midiclock.de/
Nice, looks great, thanks for the tip
What, no Sync24 :frowning:
Otherwise, it looks great.
