switched on
hi all,
this may appear a silly question but can the lp become damaged if its left on for a long duration? the reason i ask is that i was using its earlier today and something came up that i had to suddenly leave, resulting in that i left the LP switched on accidentally for about 9 hours.
i’m 99% that leaving it switched on wouldn’t damage it, as it was producing a sweet tone when i pressed the keys! :wink:
Andrew
p.s. as you may have noticed from my previous posts, i’m a over protective lp fan! :wink:
This has been asked before. The answer is, no damage will come to the LP if left on for an extended period. But expect a slightly higher electric bill. :wink:
I think I’ve had mine on for several months now…
I thought you left a vinyl copy of “Switched on Bach” playing for hours…
Epic Win! That’s funny! :laughing:
Uh wait ..there is an on/off switch? :wink:
thanks for the info…Is the oppisite true? I mean, not like this happens but, if you turn the LP on and off in a short period of time, is that bad. Not the same, but my tube guitar amp needs a minute to warm up, is anything going on like that in my LP?
The LP takes roughly 20-45 minutes to warm up. Turning it off after five minutes shouldn’t cause harm I wouldn’t think. Anyone else care to chime i on this? :confused:
Thanks for the info, I know it takes a while before warm up, to be honest not sure i’ve played it for less than two hours at a time, but this post got me thinking :bulb:
