Switch for Expression Pedal
I have a moog expression pedal that I’d like to use at the expression input port on several pedals, one at a time. Is there such a thing as a CV multi switch that would direct the expression pedal to the pedal of my choice on the fly?
Here’s one for Intellijel Eurorack frames:
https://intellijel.com/shop/eurorack/1u/switched-mult-1u/
Thanks for that. If I understand correctly, it splits a single signal into multiple signals to control multiple parameters simultaneously. As cool as that is, I’m looking to assign the expression pedal to a single effect parameter, and then hold that parameter while I assign the pedal to another effect parameter, etc. I’ve learned that the expressionator by mission engineering can do this. Super super cool. https://missionengineering.com/shop-2/products/expression/multi-use-exp/expressionator/
Ah, that’s a bit different now. In the development world (differentiated from the developed world) we call that scope creep :mrgreen: .
Wasn’t aware of that Mission Engineering box-very cool. The other one to look for (used) is a Moog MP-201 pedal/processor. It’ll do what you want with 4 cv outputs and plenty more.
