I have a question that is probably obvious but I have not been able to figure out. So I setup a split with a bass in the lower octaves and a lead in the upper octaves. How do I setup the lower split with the bass sound to not respond to the sustain pedal? I’ve been screwing around in the mod section and set Sustain with controller sustain to 0% and it is still sustaining. I’m sure it’s simple but I can’t figure it out. Power users want to help sort me out?
I found a global setting under CV Inputs to turn off specific synths or make combinations of synths be the only ones that sustain, but that is global for all patches. I am looking for a patch level way to have one synth (or two) respond to the sustain pedal, while another synth (or two) do not.
As always I appreciate you as I begin to try and learn the ins and outs of this thing. Seems like it should be simple to do, I just can’t figure it out.
