super delay power off
So here is a silly question - just hooked up a new Moogerfogger Super Delay. Seems to be no power switch. So…unplug when not using or leave on all the time? Or maybe there is a hidden power switch that I can’t find? Seems really odd to me, but then I’m just a newbie.
there is no silly question here but do take time to read, read and read again
the user’s manual. I can understand the “on the spot happiness” provoke by
the new piece of equipment !
Instruction book, page 5, #4 paragragh:
Plug in to the jack > then, into the wall receptacle.
Unplug from the wall receptacle > then from the jack if necessary.
Other power infos at bottom of page 21…
When I shut it down, I turn the output,
the drive, the amount & feedback to zero first…
Congrats on your SD !
Plug all your Foogers into an outlet strip, then you can turn them all off at once. Me, I have 5 outlet strips that are needed for all my Foogers, so I just plug them all into a single outlet controlled by a light switch…
Stephen
I have always done the outlet strip method (mentioned above). I have a bunch of power squids since I have a bunch of power transformers to plug-in.
