On the MicroMoog, there is a control that has like an auto function for the S&H or it can be set to activate it as long as a keyboard is depressed.
I don’t know if this is a regular feature or not on the Voyager.
I really wasn’t very clear on what I was trying to do. I should have mentioned that I’m trying to get the S&H to alter the FILTER one step (“Vacili, give me a ping… one ping only please …”) each and every time you strike a key. New key - new filter (cut-off) position.
Christopher-
You might try setting the LFO re-trigger to Keyboard and turning the rate down to its minimum. If you’re playing really slow, maybe you could send a negative voltage to the LFO rate.
Or, why not patch KB Gate to S&H Gate?! (You’ll need a VX-351.)
Is that from “The Hunt for the Red October”?
Yes!
