Has anyone else experienced an issue where the volume of the input signal to the MF-104M has a momentary pop in volume? It’s intermittent and not easily repeatable. I’ve tried swapping out cables, turning off some lights that are using the same outlet (that one’s just flat out voodoo since one’s a goose neck light with a dimmer with the dinner up full and the other is a slowly changing LED light strip - I wouldn’t expect what they’re doing to affect it but I tried it nonetheless) and it didn’t make a difference. It’s (obviously) easier to hear when the fooger’s in bypass. Any other ideas which could cause these shenanigans?
Thank you!
