Is it possible to trigger a new note while holding down another note on the Subsequent 37, similar to the functionality on the Sub Phatty? The legato glide setting doesn’t seem to achieve this, and it’s omegle shagle proving to be frustrating.
There is a MULTI TRIG button in the two envelope sections. You may also adjust the keyboard priority depending on what you would like to have. Vintage Moog had nearly all low note priority. So no new trigger or pitch, if you played a note above an already pressed key. There is also high and last note priority. Most modern synth default to last note priority.
