Subsequent 37 MIDI signal levels
Hi folks,
I am considering the purchase of a Disting Mk 4 and MIDI breakout module to use with my Subsequent 37 so that I can simulate some CV OUT to use with a minimal Eurorack system that I am putting together with a Mother 32 at its core. However, I have read that the MIDI signal output of the breakout module is set at 3.3v which is apparently the latest ‘low voltage’ output specification in MIDI. Devices that use the ‘older’ 5v signal levels may not respond to MIDI signals at 3.3v so my question is, does anyone know what specification the Subsequent 37 works to?
Thanks.
Steve
Really, no one?
OK, in case anyone else should find themselves asking the same question, the answer is YES, the Midi 3.3v low voltage output of the Disting MK 4 does indeed more than adequately drive the Subsequent 37 and vice versa.
For reference, it is also compatible with the Mother 32 and DFAM
You heard it here first …
Thanks for testing/confirming this. It was on my to-do list, but I got distracted by some new toys these past few weeks.
My pleasure!
seems you need to ask and answer your own questions in this forum.
I miss the good old days where the net was 1% of what it is today but 1000% more cooperative.
