Subsequent 37 LFO LED bug
Does anyone else see this behaviour? When setting both LFOs to the same speed and enabling key triggering on both, I’ve noticed that when using anything other than square wave LFO the LED brightnesses do not match. For instance when a ramp wave restarts, LED 1 goes completely blank (as it should) but LED 2 just becomes dimmer.
The LFOs are definitely running at the same intensity as I mapped them each to a separate oscillator’s pitch to check that the pitches coincided (which they did). This was all done in panel mode.
Just had a reply from Amos who explained that this is normal due to one LFO’s LED being controlled by CV whilst the other is done digitally.
