May be a silly question, and if so then hopefully an easy fix. When connected to a DAW (Cubase) via USB, when I press a key I get the correct sound as intended, but then when I release my finger off the key the note is repeated. What is causing this, struggling to find a solution.
Hi!
You may want to learn about “MIDI loop” ou “MIDI feedback”. Try to search in this forum.
EDIT: try this first ![]()
