I’m trying to make the Sub Phatty Editor/Librarian work with Ableton Live and i’m struggling for the last 4 hours without success.
I could install the VST on live, i can open it, but it shows ‘Hardware disconnected’, even i can see my SubPhatty is connected on USB and is visible in Live.
I research some places saying you need a firmware update to make the VST work, so i look for the update, download it from the link below :
Very confused, poor support, no clear instructions. I’m having the same issues with the VST for Voyager. Please Moog support, could you make clear instructions to how make these things work ?
Wondering what happened…a year later and still the problems persist. No reliable usb editor connection, no reliable usb midi controller function to vsti. I’m looking for a decent midi interface for cheap but it shouldn’t have to be. Alas, and sigh as well
Hoping somebody has an answer here. I am using a USB cable to connect to my Sub Phatty to my PC and an M-Audio UNO midi interface as well so that I can use the Sub Phatty Vst editor. This worked fine for months, and now it no longer works. Nothing has changed in my setup/PC. Now when I view the editor preferences, it says “Hardware Disconnected”. Any ideas? Tried for hours last night, started from scratch, no luck. The phatty receives midi notes via USB or the midi interface with no issues. swapping did nothing.
I’ve never had this problem, but do you have the correct MIDI input/output selected in the editor’s preferences? I believe selecting the correct one is sometimes the solution for people having this issue.
Yes it’s definitely correct. As I stated this was working flawlessly, and has since stopped working. I went as far as formatting and reinstalling my OS, as I was having some wonky issues in Ableton as well. Ableton is running great now, but I still get the Hardware Disconnected error when using the Sub Phatty VST. It works fine in stand-alone mode.
There are currently new firmware and editor versions for Sub Phatty in beta testing. If you’re willing to try, you could join the beta testers group and see if your issue is resolved in the new version: https://forum.moogmusic.com/viewtopic.php?f=21&t=25663
Is there any news to this? I just bought a new sub phatty today and have similar issues with the editor as a lot of other guys. Braun, I see you use a newer firmware than 2.0.6, are you allowed to share that?
Join the beta group and let your voice be heard, maybe then Moog will up the priority on the Sub Phatty.
As Breun said, click this link and follow the instruction: https://forum.moogmusic.com/viewtopic.php?f=21&t=25663
