SubP Editor following Hardware Synth changes
Will the editors knobs change and follow when I physically turn the knobs on the hardware sub phatty?
RIght now I have the editor connected to the sub p. Any changes I make on the hardware doesnt change what is showing on the editor.
Maybe you should try this : go to the “Prefs” and check if Midi IN channel is number 1. My editor (in standalone) doesn’t work if not on Midi IN Channel 1.
Check this out and let us know :wink:
So the editor will follow the changes that i make on the hardware? If I turn a knob on the sub p then it will show it turning on the editor?
Well, on my editor and SB, the knobs are only moving when the midi in is Chanel 1.
Maybe i’m not the only one so you should try this first and let us know.
That’s how it works for me, yes. (Mac OS X 10.8.)
thanks guys. I just wanted to make sure this was possible before i start fiddling around to making it work.
