Hello!
I’m having an issue when I want to sync my new Subharmonicon to Ableton Live.
My setup is as follow:
Ableton Live - EMagic MT4 - Midi cable - Moog Midi to TRS Cable adapter
Either connecting Midi In or Clock in on the SH I can hear a kind of noise that is very audible when Cutoff is down.
So far, the only way to avoid the noise has been connecting my Korg SQ1 and synching it via Midi USB, then sending the clock out from SQ1 to the clock input on the Subharmonicon.
Did anyone have the same issue?
Regards
Kenton Thru-5 : the issue is gone ![]()
I’m having a similar issue.
I’ve got a beat step pro to an AmpTone powered midi thru to the supplied midi to TRS adapter to the subharmonicon.
Whenever the SubH receives midi data (even if its from a different channel) there is an audible noise.
Is the SubH’s midi in a noisy jack? How do I fix this?
I have the same problem :
I have a background noise when I connect, via the mini jack entry of the patchbay, my keyboard master (a PCR 300 from Edirol/Roland, which works perfectly with my Mother 32 - with no noise at all).
If anyone had an idea, that would be great.
Thank you so much for reading.
Solved for me.
