Morning/Evening All
Had a look through the forum and Sub37 Manual but can’t find what I am looking for… doesn’t mean it isn’t there mind
If I run a sequence using ‘latch’ is there a setting where I can press a new note in advance of the end of the current sequence but this new ‘start’ note is only picked up at the start of the next sequence rather than immediately and also does not reset the sequence to the start.
The latest Arturia Beat Step Pro firmware update does this and it reminded me to check if the Sub37 can
Thanks in Advance
R.
I use one of the sequencer lanes of my beatstep pro to trigger, and transpose the internal sequencer of the 37 to do that exact thing.
Thanks for the swift response… that was my next option… break out the Beatstep Pro
Cheers
R.
Make sure you set the BSP sequence to the same number of steps as the sub37, and that the step interval is the same.
Sometimes, I’ll just make the first note of the BSP sequence be the root note, and then use the global transpose fiction on the BSP to transpose my Minitaurs (sequencer lane 1) and the sub37 (sequencer lane 2) at the same time.
