sub37 OS 1.2.0 change log?
hey guys - searching didn’t return a thing. are there any other changes to the OS other than prepping it for the editor?
i.e. is it worth updating if one wouldn’t use the editor?
I’d like a fix for this annoying thing when pot behavior is set to ‘live’ mode that some patches would store the main output volume. I’m currently on OS 1.1
cheers!
It’s in the “Sub_37_Update_Instructions_v1.2.0.pdf” document that comes with the editor/firmware package.
MOOG SUB 37 - CHANGE LOG
NEW IN 1.2.0
• Full compatibility with Sub 37 Editor software
• Compatibility with Sub 37 USB MIDI driver for Windows
• MOD WHEEL added to the SEQ MOD DESTINATIONS list
• Sequencer MIDI output: tied notes of the same pitch are now output as one longer MIDI note instead of multiple
overlapping notes
• INIT PRESET settings changed: lower Osc 1 Level, Osc 2 waveform matches Osc 1, LFO Sync turned off
• Fixed LFO 2 Rate MIDI CC response
• Sequence is now saved in Panel Mode
Note: Is saved when you exit Panel Mode. Exit Panel Mode before turning off power to the Sub 37 if you want to save
changes to the Panel Mode sequence
• Fixed Sustain Pedal function (MIDI CC 64 / CV Mapping: SUST PED)
thank you - dunno how I missed that
