SUB37 Keyboard playing only 1 of 3 strokes
Hi, I have this bizarre problem.
After I plugged in the Sub37 via USB to LogicProX I just get to listen 1 of 3 notes played. Imagine I play 3 times C3 and from the 3 times I play it there is only sound coming from 1. This happens trough out the whole keyboard. When I record something in the SEQ it captures all notes, but when I try to play “live” this happens…
:unamused:
Do you guys have any ideas on what happened?
That sounds like it could be a polychain issue - from page 36 of the manual:
POLY NUMBER (MIDI MENU 3.1)
This parameter specifies the Sub 37 as a single polyphonic voice for use with other compatible Moog synthesizers. Additional synthesizers must be connected via MIDI in order to add polyphony. No two synthesizers should be assigned to the same voice. > When no other synthesizers are connected, this value should be set to OFF.
POLY MAX (MIDI MENU 3.2)
This parameter specifies the number of connected voices in a poly chain. This number should not exceed the number of connected units. The default is 3.
also check your midi ‘echoing’ from daw or other hardware..
It could cause these kinds of strange things to happen..
Worked like a charm!
It was a POLY NUMBER issue that I had 3 instead of OFF.
I guess I changed it without knowing… or maybe it was a ghost, who knows.
Thank you guys!
:smiley:
