Just curious if I’m missing something - my Sub37 works great with my EP3 but I can’t get any DAW (Logic or Pro Tools) to record the expression pedal movements as MIDI. Is that normal? All of the panel moves I make are recorded and played back correctly (including if I move the filter cutoff by hand, just not when I move it by expression pedal)
that’s normal. The filter input jack isn’t even scanned digitally (which would be needed in order to output a changing MIDI value); it’s just an analog input directly to the filter cutoff. So you are wiggling a voltage and you can hear the result but it’s nothing you can output as MIDI in that case.
In the case of the other CV input jacks on the Sub 37, the default is not to output MIDI but they will in the next firmware update if you map the CV inputs to control parameters which have a CC number (the MIDI output will be just like turning the corresponding knob, in that case). That will result in MIDI from expression-pedal movements.
