Hello all,
I have created a firmware update for the Sub Phatty, in order to clean up a few little items that were not ready in time for the initial release.
Before I put this update into production, I’d be grateful if one or two Sub Phatty owners could try it out and give me their feedback.
http://www.moogconnect.net/downloads/phatty/SubPhatty_v178_1_2_1.syx
http://www.moogconnect.net/downloads/phatty/SubPhatty_FW_Update_READ-ME.txt
new Shift Mode controls:
http://www.moogconnect.net/downloads/phatty/SubPhatty_infographic_v1_1_4.pdf
Here is a list of changes since firmware v1.0:
Responds to MIDI KB Octave CC (CC# 89)
EG Decay Speed per envelope, is now Filter EG Decay Speed and Amp EG Decay Speed.
fixed a number of bugs related to Active Panel mode.
In Shift mode, Amp EG Attack knob always controls Attack unless EG is looping
(doesn’t adjust Delay unless Delay is active, which only happens when Amp EG Repeat is on) -
Also in Shift Mode, the scaling of the Delay and Hold parameters is now correct.
Changed rootnote for all “kb amount” (key tracking) type params to 60 (was 48, manual says 60)
Added handling of SUSTAIN_PEDAL, LEGATO_PEDAL (MIDI CC# 64, 68)
CC95 assigned to Decay Speed parameter
“Gate Reset” parameters now trigger correctly in Local Off mode
wider center detent on Fine Tune knob
parameter smoothing applied to Filter Cutoff MIDI CC, and MIDI Chanel Pressure controls, for smooth, step-free filter automation.
fixed integer truncation error in “velocity to eg time” parameters (was clipped to 4 values before!) also re-scaled maximum to 10x
Filter KB Amount no longer interacts with Fine Tune.
Panic / All Notes Off by pressing Keyboard Octave Up + Octave Down buttons at same time
default knob mode really is Relative mode now (was Snap)
Thanks for taking the time to check it out!
-Amos
