Sub Phatty LFO waveform problem
I’m having a problem with my Sub Phatty that I was wondering if anyone else had encountered - the LFO waveform doesn’t respond to the panel setting at all, only to the editor software which means that live it’s stuck on triangle (which is what it starts on each time I power it up)
Have I inadvertantly locked out control of this or does it require a repair? Has anybody else seen this?
I am having this exact same problem as well. I am running OSX 10.9.4 and Ableton 9.1.5.
Everything else seems to be working fine on the panel except the LFO and AMT controls
I did do the firmware update, did this cause it?
apparently the LFO works when i pull up a preset on the preset panel, but not in activate panel mode…
