Sub Phatty firmware update problem
After attempting to updating firmware with the bootloader v2 and firmware v2.79, my synth will not boot up - only the MIDI LED is activated, no other LEDs or switches. I’m dead in the water at the moment. Is there a method to perform a hard reset? Please advise.
Hello.
Do the Subphatty make a Note calibration after the firmware update ? or it stopped responding after the firmware update ?
Be sure to not make a bootloader update a second time. It can cause some problems.
Amos,
I can’t do anything - there is no communication via USB (i.e. the SP is not recognized as a MIDI device anymore). The only thing lit up on the SP is the MIDI activity LED.
k
Sometimes on my Mac, the SubP shows up as ‘USB MIDI Device’. If you see this in the list of devices, try using it to send the update.
But if you try to use your SubP alone, without the computer, is i working ?
No the SP is dead, except for the MIDI activity LED.
Okay, so sorry but at this point i can’t help you more it never happen to me. The better thing to do, I think,is to wait for an answer from Amos.
And even better than that might be just contacting Moog Support.
I have tried twice to contact support via email. Guess I will have to call (not easy - gotta day job).
Cool I got an RMA arranged they’re gonna fix it ASAP. :slight_smile:
