Sub Phatty edtor in Logic Pro X
Can anyone please help me. I’ve had my Sub Phatty for ages now, but i cannot get the editor to work in Logic Pro X and it’s driving me mad. I want to use the editor in Logic Pro so i can send midi to my Sub Phatty and record the sound, But i cannot, for the life of me, get it to work! :frowning: i’m using an iMac 2.7 GHz Intel Core i5 running 10 Mavericks and Logic Pro X. I have very little hair left, from all the pulling out I’ve been doing!!!
Please can someone run through setting up/using the Sub Phatty with Logic Pro X? I really cannot get it to work? Is there a manual for the editor anywhere? I’ve looked for online tutorials but no luck :cry:
Hey Brad
What exactly is your problem? Can you open the editor in Logic, but not control anything with it? Or can`t you even open it? One mistake that got me wondering for a while was that right when I created a new track I chose “audio” instead of “external midi”. Only with “external midi” you can control your Sub Phatty with the editor.
Did you connect the audio and USB cables correctly?
I have no problems whatsoever with my 2009 Macbook Pro running Mavericks and Logic Pro X.
I`m not exactly the pro to help you, but I hope you can work it out soon.
radioland
Hi there,
in my case:
new software synthesizer channel - choose as plugin external instrument - setup midi channel and audio input.
the you can play the sub phatty over lpx. the just choose the editor as an insert fx …
hope this helps!
Thank you so much for your help with this guys! I now have it working (WAHOOOOOOOOO)! I can see lots of fun coming from this now.
Glad to hear that! Its really a lot of fun - I just recently spent half an evening just with the Sub and Logics Arpeggiator…
cheers, radioland
