Sub Phatty Editor Issues (Automation & More)
Hello,
I have some problems using the Sub Phatty editor. I’m running it with Logic 8 (SO Snow Leopard). In particular:
  1. I have connected the Sub Phatty with USB cable to my IMac but I use a midi keyboard to play it (USB connected too). Sometimes, when I change the patches from the Editor and I try them with the controller, long notes occurs and I have to start the sequencer to stop them. No issue if I change the patches from the editor and use the Sub Phatty keybord. May I set up anything?
  2. I have noted that when I try to write the automation of a track, I can’t see the initial value of the parameter but every times it’s zero. So I have to move the automation graph to find the preset’s initial values. I have not this issue with the Little Phatty VST.
Is there anyone how can help me? :slight_smile:
Dino
