The distance that you have to move the mouse to control the knobs that have fixed positions like Glide and Modulation Source seems excessive. I have to move it as much as an inch for some of them. At first I thought it wasnât working at all because I only moved the mouse a short distance and the knobs didnât respond. I donât know if this is a bug or not so Iâm just reporting back to you anyway.
Also, if the editor is positioned near the bottom of the windows screen and a knob is turned all the way up, it is not possible to turn the knob back down beyond a certain point because when the mouse reaches the bottom of the screen the knob stops moving. You have to reposition the editor in order to set the full range of the knob. I am able to get the full range of the knob using multiple mouse operations by releasing the mouse button and grabbing the center of the knob again but this is a bit annoying. Same thing if the editor is positioned at the top of the screen.
A few things that would be nice for a future version would be to add PC keyboard control for the knobs for fine tuning. Maybe click a knob to get focus and then use the arrow keys. It would also be nice to show a small textbox or something when moving a knob that has the exact value of the knob in it. Maybe even allow typing into it so you can just enter an exact value. Of course if you were to implement this there are a few knobs like Oscillator Wave that Iâm not sure what you would type.
Other things look good so far and Iâll continue playing around with it.
I think you can Control+Click/Drag to do fine adjustments. My Sub Phatty isnât hooked up but the UI is suggesting that some fine-adjustment is going on⌠give that a try.
Firmware loaded fine ~ Installation update went smooth under 10.6.8 but back up your sounds ~ it will wipe out saved user presets
The Standalone is looking very solid now - setting up AU is still problematic under LOGIC however-
When you set up an EXTERNAL MIDI track for the PHATTY you can not add the Editor to it - You can however select it as an insert on an AUDIO track. So far, playing that recorded MIDI back will not rerecord the SubPhatty howeverâ not quite sure of intended use and how to best set this up â and most importantly, how to take into account some way to configure the MIDI filtering so that the MIDI data doesnât wreak havoc within Logic but useful data will still be recorded⌠consulting SubPhatty Editor software manual now
hereâs the setup in Logic
in the top window EXTERNAL MIDI track is enabled - there are no slots to load the AU
in the bottom window SUB PHATTY audio track is active enabled and you can see the AU is loaded into a channel strip as an Audio âEffectâ
Standalone Editor works fine.
VST has âhardware disconnectedâ message whatever the midi settings/ports used. Communication is OK: moving the knobs on the editor affects the Sub Phatty and vice versa.
Librerian shows hardware disconnected message too.
For the Windows VST plugin: this plugin uses a special background application to open a direct MIDI connection to your hardware, outside of the plugin host application (your DAW). > Because windows is not good about sharing MIDI devices between programs, this means that you canât select the same MIDI device inside your DAW> .
The reason it works this way is because the VST standard canât pass SysEx data, which is how the Sub Phatty sends and receives preset files and global data. So, in order to manage presets on the Sub PHatty from within a DAW, a separate MIDI connection outside the DAW is needed. One way to manage this is to use the Sub Phatty USB connection for communication with the Editor plugin, and the Sub Phatty standard MIDI connectors and a separate MIDI interface to connect the Sub Phatty to your DAW. Or vice versa (USB for the DAW, standard MIDI for the editor plugin).
Read Instruction .txt
I asked Amos about that because I was hesitate to buy a Midi to USB interface because I donât get Midi Din on my Audio Interface, he said that this will be fixed soon.
However on the standalone version I tried to save preset and load them, this work correctly for the sounds but the name of the preset didnât get saved.
I know this, I have read the instructions from Amos.
Problem is I am not using the same midi interface! I have explained my issue more in details in the firmware bug topic.
There is another guy for whom it works. Not for me
Okay sorry didnât see that you already post that. I donât know how work Logic so i canât help you for this, I saw that you wrote that you disable all interaction between your Midi connection so theoretically this should work . Sorry for you but like said Amos, a solution will be there soon so we just must wait a bit .
Just installed the version 0.9.1 of the SubPhatty Editor on my iMac OS 10.8.4.
I noticed the installed did not installed it properly, until I deleted the older Editor version manually.
Observations & wishes:
Wouldnât it be nice, when the standalone editor would select a SubPhatty as Midi in and out put manually per default when it see one one connected?
Standalone version only: Using the SHIFT MODE FEATURE TAB is not resizing the window, but appears to close it and reopens a new one very quickly. Other software I know does it somehow smoother and just resizes the window without a flickering on the display. But this is just thing of beauty and not of a function. So this is of minor importance and may due to the multi platform code used.
VST version running in Reaper64 bit: When using the SHIFT MODE FEATURE TAB the first time after opening the plug-in (it opens with expanded view), the lower rim of the non expanded view is missing. See attached screenshot.
A few issues I have come across, not sure if bugs or things that havenât been implemented yet:
Logic 9 Pro in 64-bit mode fails to recognise the Sub Phatty Editor. [Edit: Actually, it also fails validation in 32-bit mode. But it works fine in Live 9 in 64-bit mode. So maybe the problem is with Logic 9. I have version 9.1.8]
If I rename a preset directly into the Sub Phatty Presets (the column to the right), and save the bank, it fails to save the name. Next time I load the bank, the preset is still called â(no name)â. However, I can save (and name) individual presets in the editor, then drag a selection to that Sub Phatty Presets, save the bank, and it works. Next time I open the bank, the names are there.
Some selector knobs donât seem to work in the editor. I canât change the Glide Type, LFO Range, Wave Mod Destination, or Gate Source. The only ones that work, from those type of knobs, are the ones in the Sub Phatty front panel: i.e. LFO Source, Oscillator Octave, etc.
Iâm using the Editor on an iMac running OS X 10.8.3.
Not sure if this is a bug but presets are saved as 1-1.syx to 4-4.syx so you are limited to 16 presets per folder otherwise drag and drop of presets from one folder to another one will overwrite all the presets but the latest 1-1 to 4-4 ones!
YES ~ AS TIL POINTS OUT defaults are not remembered - so (at least on my machine) you have to reset the MIDI prefs to SUB PHATTY each time you open the Standalone or the Plug-in versions⌠then click something and wait for the "disconnectedâ message to go away â once you are connected the number of firmware version will appear above the editor version number
then you should be good to go
The standalone program icon on the Mac is the famous âMoog noteâ. This is good looking, but somehow it is not descriptive at all, as it is just indicating Moog. And this could also suite to other Moog editors like the Minitaur or the Voyager. So maybe an icon with a SubPhatty reference like the Minitaur editor icon with the bull would be more suitable.
Standalone 64 or 32 shows âHardware disconnectedâ nevertheless turning the editor parameters affects the Sub Phatty and vice versa from Sub Phatty to editor as long as Sub Phatty is selected as In and Out.
None of my Keyboard controllers works on the editor no matter USB or DIN.
VST crashes Cubase 7 normal or JBridged.
Windows 7 64 Ultimate
Cubase 7.0.4 64
Novation Remote SL
