So, I’ve got a Minitaur on the way and I have a Sub Phatty, can I use these two in conjunction for massive effect?
I’d like to sound as thick as a Voyager is poss…
I’ve also got a moogerfooger LPF and a Mini Drive
Yes, they will go nicely together
run MIDI out from the Sub to MIDI in on the Minitaur, then Audio out of the Mintaur into Ext. Audio In on the Sub and use the mixer to add the Minitaur’s oscillaors to the Sub’s. Remember though, that the Minitaur has a note range limited to bass. Have fun!
BTW, you’ll have 4 osicllators at your disposal this way - more than the Voyager!
That sounds excellent. I’ll be giving this a try when I get all setup.
