Sub Phatty Active Panel high pitch noise only.. Help!
today I connected my Sub Phatty and everything worked as usual, but at some point I changed the Filter Pole and after that in active panel mode just high pitched noises are played.
Nothing responds to changes but presets work fine and are tweakable.
I already tried reverting the Filter Pole change but that didnt work.
Perhaps I just overlooked something but it’s really strange. Any help would be nice!
Thanks in advance.
Daniel
you might try switching into Active Panel mode, and then doing an “initialize preset” command to reset the panel sound to its default settings.
http://www.moogconnect.net/downloads/subphatty/SubPhatty_infographic_v1_1_4.pdf
once you are in Active Panel, enter Shift mode (hold Bank 4 button + press Activate Panel button) and then press to light up the Bank 3 and Bank 4 buttons, and the Patch 1 button.. then press the lowest C# key on the keyboard twice. This should reset the current sound (which will be the Panel sound if you were in Active Panel mode) to its default settings. Hope this helps.
It worked! :smiley:
Thanks a lot Amos! You are the greatest! :slight_smile:
Your support and direct involvement with the community is absolutely awesome.
