sub phatty absolute min and max input voltages
The control voltage inputs are documented in the sub phatty user’s manual:
Control Voltage In
The PITCH CV, FILTER CV, and VOL CV inputs each accepts an expression pedal (such as the Moog
EP-2) or a control voltage signal from 0 to +5 volts. If you connect an expression pedal to VOL CV,
you can use your foot to control the Sub Phatty’s output level. If you connect an expression pedal to
FILTER CV, you can sweep the filter cutoff in the same manner. The PITCH CV and FILTER CV inputs
are calibrated so that a one-volt change in the control voltage will result in a one-octave change in
frequency.
The KB GATE input accepts a +5 volt signal, which causes the Sub Phatty’s envelopes to trigger
My question is:
What are the absolute minimum and maximum control voltages for inputs; filter, volume, gate and pitch?
E.g. will +10 or -10 volts into any of the inputs cause an electrical problem?
