Sub** editor - Bug report - MIDI Channel
I’m sure this applies to all editors and Sub synths by Moog.
On Ableton, MIDI notes could be sent to SubPhatty by passing MIDI through the editor if you set the ‘Echo MIDI from Host’ setting to ON.
However, this only works if SubPhatty MIDI ch is set to 1.
The editor is missing a ‘use this channel when echoing Host MIDI’ setting.
Since I’ve developed an editor/librarian for some other synth before, I have experience with this issue.
For the ‘Echo MIDI from Host’ feature to work properly, you need to convert the Host MIDI note channels to what the SubPhatty ‘MIDI input channel’ is set to, before they are sent.
I would very much appreciate if you could quickly update the editor with the ‘set outgoing MINI notes channel’ seeting.
It really is a very small modification.
Thnx a lot.
firmware: v2.0.3 , editor: v1.1.0
