Sub 37 works fine with output, Mother 32 no sound
Dont know whats going on, everything works with the moog sub 37 with input 6 and now with input 5 no sound comes out of this thing..
I have the focusrite 26 firewire , I even tried two other inputs no luck.. any ideas?
This the Saffire PRO 26, yes?
Not sure from your description what the exact problem is.
Sub-37 works but Mother 32 doesn’t - is that right?
You have Sub-37 on input channel 6 and it works, but the Mother 32 on input channel 5 doesn’t - is that right?
Try swapping them over and see if the problem is with the channel?
If that doesn’t work, a detailed explanation would be helpful in isolating the problem.
Are you using a TS cable for the Mother, or a TRS cable? You need a TS cable for proper output levels from the Mother.
