Hi there
I can’t get the Sub 37 to sync to the LOGIC Pro X tempo.
Please see attachment. Is this the correct way to send midi clock to the Sub 37 from Logic?
Thank you.
Hi there
Thank you.
Thanks for asking about this – I came here looking for answers to the same question. Looks like I’ve done what you’ve done with my Logic MIDI settings for my Sub 37. I’m trying to get my Sub 37’s arpeggiator to take its tempo from Logic’s clock and it’s not working.
Fredric
I haven’t been able to sync it with ProTools either, on firmware 1.2.0. I’m guessing this is a bug that still needs to be worked out?
What I currently do as a workaround is get the arpeggiator tempo close using tap tempo, record midi notes of the arpeggiator into ProTools and then manually adjust them to get them into time.
If I try to sync tempo the way the manual says, it just turns the arpeggiator off - the arpeggiator light will still be on, but when you hold down a note on the keyboard no sound comes out. The pulsing “Rate” light also stops blinking.
