I recently acquired a Sub 37 (amazing) and shortly afterwards learned about the potential to build a nice, big fat, slim pahhty poly chain. Delighted with the prospect I got myself my first Slim Phatty with a view to building a bit of a poly monster. Initially I wanted to get going with my Sub 37 + 2 Slim Phatties and go from there.
The reason for this post is two fold.
First, I was very disappointed to learn that it is not possible to send patches from the SP to the Sub 37 and vice versa.
Bummer.
I’m not one for using purely presets but they’re a damn good place to start and the prospect of building all of my Sub 37 presets from scratch on the Slim Phatty is not one that I’m attracted to.
So, does anyone know of any shortcuts around this or if not, are there any plans to build this functionality into the Sub 37?
On to issue number 2…
Having done a bit more research, I landed on the option of using my Sub 37 as a controller for the Slim Phatty chain so I acquired a couple more Slim Phatties. The set up I have now is as follows:
- Sub 37 (Connected to my DAW through USB, Poly off)
- Slim Phatty 1 (Set to Poly 1/3, midi in connected to the out of the Sub 37, midi thru to SP 2)
- Slim Phatty 2 (Poly 2/3, midi thru to SP 3)
- Slim Phatty 3 (Poly 3/3)
All units have the latest firmware and the Slim Phatties all have the same presets loaded. The poly definitely works. In fact, it’s amazing. The problem is that I’m getting some very odd and frustrating results. I can use the Sub 37 to change patches and it changes them on all 3 phatties. Awesome! I can use the cut-off filter, resonance and ADSR on the Sub 37 and it replicates across all units. Amazing!
Alas, that about as far as it goes. If I try anything more than the cut-off, for example, LFO modulation it’s very sporadic. Sometimes it works, sometimes it doesn’t. Sometimes the cut off filter even stops working across all units; a reset of the patch normally fixes the problem but other times not.
To boot, if I use the Sub 37 just for playing notes, and use the first SP to edit a patch, it still doesn’t replicate across SP 1&2. From what I’ve read, whatever I change on SP should also change on SP2 & SP3, and whatever I change on SP2 should change the same parameter on SP3. This simply does not work. Also, if I change the patch on SP1 (by editing SP1 and not the Sub 37), it doesn’t change the patch on SP2 or SP3.
Arggghhh.
I’ve tried local on and off on all machines (although, assume local needs to be ON so you use 3 different patches), experimenting with different midi merge options, and power-cycling them in order. None of these seem to make a difference.
Is there something simple that I’m overlooking here? Do I need to have a Slim Phatties connected to the DAW through USB or something? Should I just forget using the Sub 37 as a controller and just use a midi controller and edit the Slim Phatties directly? Even better, is there a comprehensive guide hidden somewhere which I can get hold of?
Please help! I think this has amazing potential but if it’s too glitchy I’ll have to boycot as I can’t afford to lose the studio time.
