Sub 37 Sequencer Step Resolution
Anyone else have an issue with Step size in the Sub 37 Sequencer? It seems I’m fixed on 1/8, with Seq Options clearly being set to 16th notes. Ive tested and definitely a 1 bar loop only sounds 2x.
Ive tried initializing and using the editor to fix this. Im lost. :0
thanks
I’ve sussed it out, I was using ableton as a mixer (basically it was just open and allowing sound). Everything was set right except sync being activated on the sub 37. Works as expected now.
