Sub 37 Routing Question
Is it possible to Route the pitch bend to aftertouch? I want to be able to bend the notes by applying pressure to the keys/
You could do it using a mod bus by going into the mod bus controllers menu and setting source as constant on, setting a percentage for aftertouch and then moving the pitch knob for that mod bus, giving the desired range and oscillators to be affected (osc 1/ osc 2 / both).
Page 50 of the owners manual covers the controllers menu part of it.
If you do it with mod bus 1, remember that by default the amount of modulation is set by the mod wheel, but you can dial that out in the controllers menu.
