Hi!
My Sub 37 only plays the first note when Latch is on in sequence mode. I have viewed the other post on the same subject, but the answer did not solve the issue. (my cv mappings are in default (not st1 reset)). Also when the sequence is latched and I press and hold a key, the sequence will pitch up every time it starts over. I cant seem to find the answer to this problem either in the manual or online, but i`m sure one of you guys can help me out.
Thank you for your help ![]()
sounds like a MIDI loop - if you are sending MIDI out from the synth and that same MIDI is being sent back to your synth from a DAW, it might be causing this. You can turn off Local Control on the synth or turn off the monitoring in your DAW that is sending the synthโs own MIDI output back to its input.
also might be some improvements in the newer firmware (currently in beta) to help it work better even when there is a MIDI loop as described above.
hi -
i was having the same problem and it was indeed a midi loop. thanks!
