Thanks, Dan, coming from you that means a lot!
It’s the Magic Fingers Vibrato, with the width turned way back. I like the stereo field I get from it and a something-something like the old Roland Dimension D…
Mike
Mike
Hey guys, thank you for your precious help!
Actually i decided to buy a Styrmoon Timeline, it shall arrive tomorrow or the day after. I will let you know how it works! ![]()
The Timeline’s a really nice delay. I thought long and hard between the Timeline and 104M, before finally choosing the 104M as I just liked the sound and tone a bit more than all the added functionality the Timeline provided. As it turned out, I wound up with the 104M-SD cause the shop I ordered through sent me the wrong one.
They told me to just keep it when I informed them of the error. I really like them now. ![]()
Wow. That’s way cool. I like my 104m so much I will probably end up getting the 104SD to make the perfect dual delay set up…Other than the creamy tone of these, I really like that you can get a very convincing wow and flutter by modulating time with the sample and hold waveform-rate set between 12-50 and amount between 1-2. Great fun.
-Mike
Just ordered the Minifooger Chorus (from a store you might know Dan!) to replace the iStomp, which I like but I think is beginning to sound a little, well, digital to my ears…
strymon makes great pedals, doubt you will disappointed, however, they are digital (not that I’m an analog snob by any means) and the 104M is simply in a difference class
I have both, as well as some others, and I wouldn’t give up my 104M no matter what
the one drawback to the smaller model strymons is that they have no midi control…that being said, I still love my el capistan for digital tape delay and deco for doubletracker
in addition, strymon’s support is stellar, just like moog
you can find used 104M now and then too…heck, I’m even selling one since I was able to pick up the SD
the other thing to keep in mind about the 104m, it will likely hold it’s value for a long time
minifoogers are nice value if you don’t need the midi/modulation but still want the sound
Hey y’all, I’m new to the forum (having just bought a Sub 37) but digging all the informative posts so far. And REALLY looking forward to the new 37 firmware-- the sequencing updates look awesome.
Anyway, I just wanted to add my 2 cents re: delay pedals because I’ve owned way too many of the damn things, including a bunch of the ones mentioned (Flashback, Timefactor) and plenty more not (original EH Deluxe Memory Man, Maxon AD-900 and on and on)…
Bottom line? I’ll never get rid of the Memory Man because the tone is unreal. Haven’t played the Moog everyone’s going on about, but I understand the enthusiasm for great analog delay sounds.
But-- the MM is big, limited and sucks tone due to its signal path design. For features AND sound, you can’t beat the Timeline. For years, I only allowed analog pedals on my board, but once you find a great digital delay and explore all the sounds it can provide beyond the basics, it’s hard to justify the “analog only” ethos, IMO.
Functions like looping, backwards delay, sync’d tremolo and panning, stereo ping pong, etc. with a synth is way too much fun to pass up just because the Strymon isn’t analog. And that’s just scratching the surface. Presets, MIDI clock sync, expression pedal control of ANY parameter and totally bizarre sounds like bit-crushed delays that you can’t find outside the digital realm open up huge sonic possibilities.
I think you’ll love the Timeline. Strymon’s El Capistan was the first digital delay I ever bonded with, and IMO their modeling is unparalleled, even when compared to Eventide and TC, whose pedals I rejected as sounding “too digital”… Enjoy!
I love my Eventide Space (but that’s a gear shift to reverb) …just sayin’ ![]()
like you said, I think the El Cap is the king of modeled tape delay…for what it’s worth, you can get tape delay type sound from the 104M as well (it has an LFO to work with)…just not as in depth as the El Cap…Strymon’s own Timeline isn’t even as good as the El Cap in the tape delay department…the El Cap does a great job at what it was built to do
but again, if I had to give up all my delay pedals except one, the 104M isn’t going anywhere ![]()
I’m using an old Ibanez HD1500 with mine. A friend owns the MF Delay and it’s so warm and musical, I was really impressed with how excellent it sounds.
I’m using an MF Delay with the Sub37 and think it sounds great, is easy to dial-in, and will power off a battery if needed. I actually have two, and use the other one with a Microbrute, and have successfully used CV to create modulated delays.
Also in play is a Hardwire Supernatural reverb pedal, so I got that going for me. Which is nice. ![]()
Regarding the MiniFooger Delay’s capability to use cv, here 's a quick demo using the Sub 37 and a Werkstatt plus the delay. The 37 controls the Werkstatt via MIDI, the Werkstatt is used as third oscillator for the 37 thru the external input and the Werkstatt’s LFO controls the the delay time of the Fooger.
Dan, can you please give me some clue how to reproduce the sound you use from 10:56 till 13:36 in the video. It is an amazing sound!
I use a Boss DE 200 or a Roland SDE 2000.
I bought the TC electronic flashback and i’m very happy with the sound, going to use it tonight for the first time with my band! ![]()
Get the Strymon Timeline, it’s the best delay ever made. The possibilities of it are endless
I have the Strymon Timeline so I will add another vote for it. However if I add the money I would also get the MoogerFooger 104M. Just picking up my Strymon Mobius from UPS this afternoon.
Hi Toine,
It’s one of my favorite analog synth tricks, yet very simple.
I’m using a Sub 37 Preset I made called “For Your Echo 500ms”.
(In the near future, I’m going to start releasing all my custom presets, one at a time, with informative notes.)
Use a single Oscillator, set to Sawtooth, and choose a very low Octave setting - high enough that you still hear it as a pitch, but low enough that you start to perceive its individual cycles as rapid clicks.
Then send it through a Low Pass Filter with enough Resonance such that, when you sweep the the Filter Cutoff, you can hear clicky pitches as you pass by each of the Sawtooth wave’s harmonics.
Now run that into a stereo ping-pong delay set to around 500ms, and presto…
Then you can decide if you want to do the Filter Cutoff sweep via the knob, a Mod Wheel assignment, a Filter EG, an LFO, etc.
Thanks Dan, looking forward to the release of your presets!
I’ve had good results with my el capistan, but my favourite is the good ol’ re-201 … here’s an example:
