Hello all,
I received my Sub-37 yesterday and was very excited. Unfortunately, multiple issues have arisen:
The pitch wheel problem—same as THIS thread. The pitch wheel appears to be stuck on +2 (or whatever the bend up value is) for me, while the bend down achieves twice the bend value (in my case, -4).
Intermittent notes—this is the bigger problem now. To troubleshoot the above problem, I tried to test out an external keyboard controller’s pitch wheel. I use an Alesis QX25 USB controller. I checked to make sure it was outputting on the correct MIDI channel then plugged its DIN out into the Sub37’s DIN input. A few notes played fine, but not long after the note input became intermittent. I unplugged the keyboard and rebooted the Moog, but even on the local keyboard it seems that the moog only registers 1 out of every 4 times I press a key as a note. Weirdly enough, if I have the arpeggiator on the problem goes away and all notes seem to register. I tried reinstalling firmware v1.1, going back to 1.0.7, and back again to 1.1, but no transition seems to be fixing the problem.
I should mention that before buying the Sub 37 I tried it out in a local guitar center. When I sat down to play with it, I immediately noticed this EXACT same problem. I let the guys there know, and they said they’d take it off the floor and fix it for the next day. I am not sure if they did or not, never heard back. I passed it off as a fluke, but clearly it is a repeated problem.
I’ll contact tech support when I can, but for now I would love to know if anyone else has encountered this and if there are any solutions I’m missing.
~Matt
