Hello everyone!
My first post here is a desperate cry for help. I have searched and read through tons of posts on the topic but still could not solve the problem.
I am using Logic Pro X as Master and would like it to trigger the Sub 37 Arp/Sequencer. My audio interface is MOTU Ultralite MK I. The Sub 37 is connected to a MacBook Pro via USB. I have created external midi instrument track in Logic for the Sub 37 and a separate audio track but when I press play/record in Logic, the Sub 37 does not produce any audio or midi. I have pressed the ‘Sync’ button on the Sub 37 and the midi button was blinking red but there is no audio.
I have tried different permutations with regards to the settings on both Logic and the Sub 37. I am slowly losing my mind.
If anyone of you have similar setup and things are working for you, please help!
Thank you!
