I’ve just encountered a problem and I’m not sure if it’s an issue with the Sub 37 or Ableton. Maybe someone on here who uses both can advise me what I’m doing wrong?
Simply Live has stopped picking up midi from the Sub 37. I was using it as my midi keyboard and it’s suddenly stopped working. I can’t see anything that I’ve changed. On the out filters I have keys on, I have midi out to both Din and Usb. I have set midi channels to ‘all’ on Live, yet nothing. This just happened over night.
Now just realised that the Sub 37 editor is not receiving midi notes either. It’s synching up presets with the editor ok, the midi light even flashes when you change octave but no midi note data being received.
*Further update, the editor is now not receiving any midi sync with the Sub 37
Sorry to hear that.
with any of these issues the key is to isolate where the problem is. Start simple, hopefully with the bits that work then change 1 thing at a time until it stops.
So…
Connect headphones to Sub37 just to be sure it is making sounds
Beg/Borrow another keyboard
test it with Abelton
test it with Sub37
Use the “Sub 37 Editor Standalone.exe” (no Abelton)
Reseat your USB/DIN cables
Reset the Sub37 from the Sub37 itself > SUB_37_MANUAL Page 49 INIT SETTINGS (GLOBAL MENU 3.2)
Check the OUT FILTERS again - all ON
Run MIDI-OX (http://www.midiox.com/) and check that “normal” MIDI is being sent, note on/note off etc rather than intermittent or continuous random stuff.
Sub37 Arpeggiator ON + LATCH so that continuous MIDI is output from Sub37 and appearing on MIDI-OX Monitor-Output
Sub37 Editor > SETUP > EDITOR SETTINGS
Reset the MIDI INPUT/OUTPUT - change it to something else then back again to force it to re-read the connection
on my rig these show up as “2- MOOG SUB 37 IN” and “2- MOOG SUB 37 OU”
Re-install the MIDI driver - for Windows7 it is “Moog_Sub_37_USB_DriverSetup_v2.23.0.exe”
