Hey everyone,
I have a Sub 37 running the latest firmware (1.2.0.)
I have a Kurzweil Micropiano module connected via the midi out so I can trigger the Kurzweil sounds. When I have the volume of the Sub37 in the off position I have no problems. But when I turn up the volume on the Sub37 the Kurzweil module suddenly mutes and doesn’t make any sounds. replugging the midi cable does not help. It’s only when I reboot the Kurzweil module can I get any sound out the Kurzweil. Any thoughts?
Scott
Hi Scott,
In the MIDI menu of your Sub 37, check the settings in the Out Filters. You can filter out the MIDI signal for knob turns, pitch and mod wheel, or keyboard if you so choose.
Hey Taylor-
Thanks that worked like a charm.
Just one more head scratcher. The mod wheel works fine on the Kurzweil Module but the pitch wheel doesn’t affect any of the sounds. Is there a setting on the Sub37 I need to change? Thanks.
Scott
From the MicroPiano Manual:
The MicroPiano does not respond to Pitchbend messages.
Problem solved
