In the manual tell how sync Arp, Mod1, Mod2, etc (ALL theese SYNC buttons ) with “Internal or External Midi Clock”
But I can’t find WHERE to select if I want to run with Internal or External Midi Clock if one present.
Any help?
Any help?
Hi artofnois,
If I understand correctly, you’re looking for a “MIDI SOURCE = AUTO” setting that automatically chooses Internal Clock when there is no external MIDI Clock present, and chooses External MIDI Clock when there is external MIDI Clock present.
No such parameter currently exists on the Sub 37. (If that’s not what you’re looking for, then below is your answer.)
The choice of Internal Clock or External MIDI Clock is made per preset via the ARPEGGIATOR’s SYNC button.
The other four SYNC buttons on MOD1, MOD2, FLT EG, and AMP EG chose if they each sync to the ARPEGGIATOR (regardless if the ARP is sync’d to the Internal or External Clock).
In other words, the ONLY place to choose Internal or External Clock on a Sub 37 is the ARP’s SYNC button, and that’s per preset.
OK. I see.. manual is very confussing .
And other question about this.
In the manual page 49 say:
LFO 1 SYNC 2 425 3 41
LFO 1 KB RESET 2 426 3 42
LFO 1 CLK DIV 21 427 3 43
LFO 1 CLK SRC 2 428 3 44
LFO1 SYNC is the equivalent to button sync in MOD1, but LFO1 CLK SRC say that can be 2 values (which?).(Internal/External?)
What this parameter is? Select the clock individual to MOd1, apart from Mod2 an apart from ARP/SEQ?
I havo no found on synth a way to change this parameter. Only see on manual
Hi artofnois,
Interesting find!
My guess is that the LFO 1 CLK SRC and LFO 2 CLK SRC text (page 49+50) may have been copied/pasted from a previous manual, or is a remnant from an alpha OS when the LFO Clock Source was envisioned differently.
I’m fairly certain that the SYNCronization of both LFOs and both Envelopes are only to the ARP, regardless of whether the ARP is following Internal or External clock.
But I will get a more definitive answer for you…
I will be waiting for your answer, like ever
As suspected, the LFO 1 CLK SRC and LFO 2 CLK SRC text (page 49+50) was inadvertently pasted to the NRPN Chart.
As it currently stands, the Sub 37’s SYNCronization of both LFOs and both Envelopes are only to the ARP, regardless of whether the ARP is following Internal or External clock.
But the Sub 37 is always evolving into a more sublime instrument of expression, so… who knows?
Ok. Thanks. I must to remove both combos from my editor… ![]()
Where get you that information?
Have you a link to the Gods?
If so, can you beg us for a sysex documentation forthe nere mortals?
It’s a Ouija Board, but it has lots of electrical and musical symbols instead of letters.
(I’ll wiggle the planchette, but it seemed like they were firm on that one.)
