I suppose you are referring to version 1.1.0, as there is no version 1.10. The Sub_37_v_1_1_0.zip file contains a folder called Documentation, which contains a file called v1_1_Change_Log.pdf, which seems to be what you’re looking for.
It contains the following information:
MOOG SUB 37 - CHANGE LOG
New in 1.1.0
• Sequencer Step Edit Mode
• Quick mapping of programmable Mod Destinations
• Sequences can now include Skipped Steps and Ratchet
• Swing for the Arpeggiator, Sequencer, & Synced LFOs
• Sequencer Mod Destination
• Sequencer Mod Only
• CV Mapping
• Sequence Mod Amount, Step 1 Reset, Ratchet Count, via CV Mapping
• Sequence Step Advance, Sustain Pedal, and Gate Invert for Gate CV Mapping
• Variance parameter for detuning of oscillators
• Fixed sequencer MIDI output now sends MIDI notes for both Pitch 2 & Pitch 1 when in Duo Mode.
• Fixed when LATCH is on, playing a key, changing KB OCTAVE and then playing the same key now updates the
played octave correctly.
• Fixed Amp EG Latch ON no longer affects Filter EG.
• Fixed Preset Name now updates when you INIT the preset.
• Fixed Pitch Bend Up/Down changes now take effect when Local Control is OFF.
• Keyboard Transpose/Quick Keyboard Transpose
• Tying/Untying Groups Of Steps
• Adding/Removing Rests
• Nondestructively choosing start/stop points
• Rotating Sequencer Pattern
• Sequence Send/Receive via SysEx
• Editing Hi/Lo Note in DUO Step
• Latch Restart
• Delay Program Change
• Volume Calibration
• Send MIDI Start/Stop
• Follow Song Position Pointer
• Sequence Page Chase
• Refer to Sub 37 Manual for complete list of changes in v1.1.0
New in 1.0.7
• Fixed parameter mismatch when Master Volume set by MIDI (CC7) • Mod buss CTRL4 (MIDI CC 2) value now updates correctly
• Improved Relative pot mode behavior when reversing direction
• Pot min/max values now reported correctly, fixes Pass-Thru pot mode
New in 1.0.6
• Fixed MIDI Time Code handling (MTC is ignored). • Fixed MIDI Output Filters - Panel, Wheels.
New in 1.0.5
• Small improvement to main CPU startup routine.
New in 1.0.4
• Added MIDI Clock/Start/Stop output (GLOBAL MENU 2.5: CLOCK OPTIONS)
• Panel Mode gets correct rotary switch positions
• Change in External Sync behavior: does not require MIDI Start message
• Fixed possible MIDI loop when Local Control turned off
• Fixed bug where Mod Wheel value didnʼt go completely to zero via external MIDI
• Velocity is now updated when re-playing an arp note which is already latched
• Fixed stuck notes via arpeggiator MIDI output
• Improved USB MIDI reliability
• Fixed NRPN output/response for Mod 1 & 2 PGM Destinations and Sources
• Fixed bug that could cause arpeggiator to freeze
• Output Mute button did not work under some circumstances; now always works.
• GLOBAL menu now shows both main & panel firmware version numbers.
• MIDI menu: POLY MAX number display was off by one (values are 1-16, was showing 0-15)
New in 1.0.3
• Fixed possible freeze during patch changes
• Fixed: after scrolling rapidly through presets, patch select LEDs could remain lit
• When exiting compare mode, patch edited status is correctly restored (asterisks reappear if necessary)
New in 1.0.2
• Custom tuning selection
• Poly mode
• MIDI output filtering now includes keyboard and wheel options • Arpeggiator and sequencer reliability improvements
• MIDI sync behavior fixes and improvements
• Numerous other user interface reliability improvements
New in 1.0.1
• Arpeggiator rate knob responsiveness improved
• Tap tempo no longer requires SYNC to be on
• Arp and LFO rate knobs now give correct settings at maximum position • LFO 2 Sync at max tempos and max clock divisions is now stable
• Pitch CV reliability improved
• Local Control: KNOBS is now Local Control: PANEL
The most recent version of the Sub 37 firmware is 1.2.0 by the way, which is included in the Sub 37 software editor download (Sub_37_Editor_v1_0_0.zip), since the Sub 37 software editor requires firmware 1.2.0.
