Hi MOOG.
I’m quite excited with my brand new Sub37 and looking forward to know all the insides of this beast. I can now say confidently that I don’t regret having sold my Little phatty for this great upgrade.
NOW:
Can somebody explain me a bit better the fine tune knob as a tuning control? on the Little phatty it could be enabled or disabled. But I don’t see the parameter now.
Also, is there a quick way to bring back the pitch to “440Hz”? There is no center detent on the pot so I’m never certain that it’s back to 440 just by looking at it.
I found your post interesting and did a simple experiment. I had this theory that there was this dead zone around 12 o’clock where the synth would always be in perfect tune. As it turned out that didn’t seem to be true. I tried a couple of tuners. The first being my Korg Chromatic Tuner but the resolution isn’t fine enough to determine that. Then I tried a tuner on my iphone which was a bit laggy but much more detailed and it pretty much disproved my theory about the dead zone.
Then I started thinking about it and realized dead zone / notch or not, the synthesizer is a living instrument and the environment will most likely affect tuning to some, however small, degree. So, my conclusion is that if you need it to be perfectly tuned there is now way around using a good tuner.
The tuning on mine was just a little bit off at center position but I could probably only hear it if playing with other instruments. I have never retuned mine so it might be possible that tuning might be improved.
One way of bringing it back to 440 would be to start with an init preset and save it occasionally so you can reload it in tune if you happen to accidentally touch the fine tune knob.
I checked yestereve with a guitar chromatic tuner what was the sensitivity of the fine tune knob. Basically, you have +/- 1/2 tone, and the ‘flat’ area where my tuner was not discerning any changes was rather large around 12 o’clock. So basically, I think we have enough precision to be in tune with others.
There is no 440 reference on the Sub37 and no way to turn off the fine tune knob. The fine tune knob doubles as a parameter knob in some edit functions, but will always revert to fine tune when not in edit mode.
Although there is no parameter to disable the FINE TUNE knob, it’s not right next to a busy VALUE knob like it is in the Little Phatty.
So, hopefully, you’ll be less likely to inadvertently move it.
It’s probably worth it to at least learn where your FINE TUNE knob needs to be for 440Hz.
Let the Sub 37 warm up a little and then use an external tuner to get it exactly in tune.
Be sure to use an INIT PRESET (MW all the way down) so that you know you’re only using one OSC with no modulation.
If the FINE TUNE knob is perfectly straight up, then great! It’ll be easy to remember.
If it’s off to one side or the other, you can use a small sliver of colored electrical tape to show exactly where to point it.
