The Sub 37 Editor V1 is mightily impressive. Here’s a little wishlist for V2.
EDITOR
Randomness - a bit less random please for more musicality, like a Dial or by locking modules such as FILTER, GLIDE etc
better visual feedback when your DAW changes the knobs. The little white tip is easy to miss. Maybe the knob could glow or pulse - like the Moog logo does when MIDI is transmitted
have GLOBAL LIGHT SHOW assignable to a MIDI CC - to confound my enemies
SEQUENCER
** Randomness - again, a bit less random, eg limit SEQUENCER to +/- 12 semitones, no REST/TIE etc
** Sequencer STEP SETTINGS - have ROTATE PATTERN assignable to a MIDI CC (already can do this on the hardware BANK < > )
** record from MIDI input or DAW
** load a MIDI file somehow - 1st 64 steps would be fine
** save sequencer as a MIDI file
SETUP
++ when loading the Sub 37 Editor, automate turning off GLOBAL SETTINGS - Keys, Wheels and Panel, to prevent MIDI issues. At power up, auto-turn on Keys, Wheels and Panel. I always miss this part.
MAPPING
Save/load MIDI CC MAPPINGs - XML format please.
LIBRARIAN
^^ A definable default location for loading/saving all .prefs, .seq, EXPORT and GET, CC MAPPINGS, MIDI/GLOBAL
Personally I would be putting all these into the DAW’s project folder. New project = new folder
^^ Somehow retain the Bank/Program Change value in the Preset Library .SYX file so it can be loaded back into the same hardware memory location. Currently I name files this way - “B16P16pc127 Drum” just to be safe.
^^ In HARDWARE PRESETS have a Bank/Program Change column display. So Bank 1, PC 127 would line up with B16-P16.
^^ Save/load MIDI/GLOBAL settings separately
^^ speed up EXPORT/IMPORT BANK - a 200KB file takes 3 minutes?
Also can Sub 37 have it’s own Forum?
Thanks!!
