Sub 37 - Duo mode - Note bleed
Excuse my inadequate synthesiser lexicon. :stuck_out_tongue:
I would like to operate the Sub 37 Duo Mode in the following way: When a note is pressed, oscillator 1 is used, and follows the normal cycle according to the amplitude envelope. If I then press another key while oscillator 1 is still completing it’s cycle (still in it’s ‘release’ phase), then oscillator 2 will be. In this way, the notes would ‘bleed’ into each other, and at lower registers would result in ‘beating’ which fades out as oscillator 1 fades out, leaving oscillator 2 sounding.
My understanding is that, since the two oscillators share the same envelopes, this would not be possible. So I am looking for a fix which would involve the mixer section – using the ‘Osc 1’ and ‘Osc 2’ controls to achieve this.
