Sub 37 copy/paste sequence
Hi there,
I need to know if there is any way to copy step sequence (1-16) and paste (16-32)and going on?
Now I saved two same presets sound with different sequences, is this the only way?
Any hints?
Curious myself.
Although not exactly the answer to the question you’re asking:
It is so easy to see all the Pitch, Velocity, Modulation, Rest/Tie, and Skip/Ratchet information of the Sequence data on the forthcoming Sub 37 Editor that, it will be easy to manually make all of those values in 17-32 be identical to those in 1-16.
