Sub 37, Can´t select letters with "fine tune"
Hi List
I´m new here so sorry if this subject has been up before.
Yesterday everything worked perfectly but today when saving a sound I can´t use the “fine tune” knob to select characters.
Any ideas?
I have the Sub connected to DAW with local off (keyz)
Best
tomas
Strange effect - same happens with mine :frowning: And it worked in the beginning, too
You should report this as a bug to Amos at Moog (amos@moogmusic.com).
Don’t forget to give your firmware version (numbers found at the bottom of the global settings), because maybe this is already fixed in the beta version of the next to come v1.1 firmware.
Greg
Global menu–> Fine Tune → Edit
Hopefully that will sort you out.
thx, will check this tomorrow!
It did work out! No idea, why the settings in the menu changed, maybe I pushed too many buttons …
If anyone else has this problem: You got two choices, tune and edit. In the tune mode you can - as expected - tune only. In the edit mode you can use the poti to edit (characters e.g.) and tune … Nice!
Great news it’s not a bug :slight_smile:!
