Hi all,
I just registered after lurking around for a couple of weeks. Such a great community!
I got my Sub 37 in June this year. Frankly, I am quite impressed. Except for an semi-analogue Microwave I it is my first analogue machine during 20 years of synth programming.
The first tribute machine had some hardware issues. The MIDI out socket was mounted out of center, so none of my cables did fit, and one black key was out of positioning. Fortunately my dealer simply exchanged the device.
The replacement machine had another issue. Switching all sources off in the mixer (the switches are an outstanding feature while programming the synth, BTW) still lets pass some serious noise when depressing a key, which gets worse when using multidrive and feeback settings. The machine now is on the way to repair. I’m curious whether the engineers will manage to fix the issue.
So my impression is: A fantastic machine (I programmed a couple of sounds I didn’t expect) but I’m worried concerning its build quality. What issue will be next?
I’m pretty sure I just got two real lemon devices and I hope I get the machien back from repair in perfect state. If so, I have a couple of lead sounds to share
ce
