Sub 37 and Modular
Hello,
I was wondering, can a sub 37 interface with a eurorack, for example if I have a couple of effects modules like a delay, ring mod and things like that can I run the Sub 37 to them?
If you get a MP-201 or some other sort of midi to cv interface like the Kenton Modular Solo that should do the trick.
Actually, the SUb 37 has 4 CV inputs but no CV outputs. That means you would only be able to control your Sub with the modular, and not the converse.
… unless you use MIDI out of your Sub and a MIDI to CV converter of any sort, including a MP-201 as suggested by Slabwax.
